 Kill switch on your scooter arron
n/a Posted - Jul 05 2003 : 4:20:09 PM
Hi arron (i think) i have seen your scooter with an engine (well it used to have an engine before you put it on your kart) and i have the same engine for my kart and would like to know how to connect the kill switch up as i know one end has to be grounded but what about the other
Darren
Kale Posted - Oct 16 2003 : 12:34:22 PM
Hehe... sounds like you need an ignition kill switch for your car Aaron.
If I ever see an RX7 embedded in a wall the first thing out of my mouth will be:
"Aaron, is that you?"
Aaron Cake Posted - Oct 16 2003 : 09:32:32 AM
Yikes. That's an evil system. You can run a ground wire to the NON-GROUNDED breaker point. Grounding that wire will kill ignition.
n/a Posted - Oct 15 2003 : 6:14:28 PM
My brother has an old lawn mover engine. don't know what make, but its a 1 cylinder 4 stroke engine, and everything uses the metal engine block as ground, the magneato (spelling) has 1 wire to the plug (which receives ground through casing) and another which goes through a 0.2 farad cap. to ground and to the breaker points of which the other side is again connected to ground. Kill switch is a metal tab about the plug, which when pushed down grounds it out, surely there is a better way if doing this, would grounding the wire on the other side of the magneato work?
Adam
cirvin Posted - Oct 02 2003 : 8:00:38 PM
(drool)
at last!!!
Aaron Cake Posted - Oct 02 2003 : 09:32:05 AM
Damn u aaron!! u have tipped me over the edge! i must have an rx7!!!!!! lol
at last!!!
LOL. That's just a little '78 with all of 100HP. Imagine a slightly modded Turbo II (86-92). Easy to get 250HP out of the engine with bolt-ons. Or my car when it's finished...bridgeported turbo 6-port high compression engine, probably into the high to mid 11s in the 1/4...
Or if you want to get fun, the 20B three rotor swap....
BEatonNo1 Posted - Oct 01 2003 : 8:43:54 PM
Yeah I can definantly see how that would take you by suprise. that sounds like a fun car to drive....
cirvin Posted - Oct 01 2003 : 8:11:18 PM
at last!!!
Aaron Cake Posted - Oct 01 2003 : 09:35:40 AM
Well yeah, that was the ultimate solution. But the real issue is when the throttle sticks, the car TAKES OFF. All four barrels of that little carb pumping fuel into a rotary that just wants to scream towards redline...Takes you by surprise, especially when the car will reach 50 MPH in 1st gear...
BEatonNo1 Posted - Sep 30 2003 : 5:34:22 PM
put it in neutral? thats what I would do, then turn it off.
Aaron Cake Posted - Sep 30 2003 : 09:35:53 AM
Try driving an RX-7 and having the carb stick at wide open...that's an experience. Especially on one of the busiest streets in London...
cirvin Posted - Sep 29 2003 : 8:06:07 PM
something happnd like that to me. that was wn my accelerator cable broke and i was waitong fdor a new one. well we had rigged it with a rope. well it stuck, th brakes don't do shit at top sped and i hadn't put the kill in the front so i had to turn around, steer, and pull the kill all at the sam time! the kill was jammed so i put it on choke and it died shortly after that.
n/a Posted - Sep 28 2003 : 3:56:02 PM
done so and its going great and has already been used as my kart dosnt currenantly have brakes and it does 63.7 MPH and the throttle jamed but thankfully i was able to kill the engine
Darren
Aaron Cake Posted - Aug 29 2003 : 4:21:12 PM
There should be a wire coming out from under the flywheel. It connects to the condensor in the breaker box (under flywheel). If you ground that wire, you will cut ignition.
n/a Posted - Aug 28 2003 : 3:20:33 PM
What kind of engine is this?
It is a briggs and stratton and it looks like the one on your scooter (well before you put it on your go kart)
But it has not terminals on the carb
PLEASE HELP
Darren
Aaron Cake Posted - Aug 06 2003 : 3:35:46 PM
