 MOSFET Switch
sergiosparks Posted - Mar 22 2007 : 04:48:15 AM
I am trying to substitute IRF450 to switch the ground
- side of an ignition coil. The gate will get its OFF command
from the old contact point.Is there some more precausion to this
like installing a damper diode ?Are mosfets preferrable than power transistor.No problem blowing some mosfets i got a bunch of them
from discarded switching power supply.
sergiosparks Posted - Mar 23 2007 : 02:55:29 AM
Wow its a lot of reading but a lot of info too !
Thanks Aaron
Aaron Cake Posted - Mar 22 2007 : 09:09:22 AM
You'll definitely need some snubbing/damping at the coil. This page should give you some ideas on driving an ignition coil from logic circuits:
http://www.megamanual.com/ms2/pcb.htm
