 hovercrafts and carts
n/a Posted - Jan 02 2003 : 4:24:29 PM
any1 know where i can find info on how to build either of those . preferibly(sp?) cheap and easy to build.
Aaron Cake Posted - Nov 17 2003 : 9:50:39 PM
i heard you could put the lawnmower motor on the back of the kart shaft down and put a pulley on and put a pully on the rear axle
You would need a clutch. Really, I wouldn't waste my time trying to use a vertical shaft engine UNLESS you have no other choice.
cirvin Posted - Nov 17 2003 : 4:45:33 PM
yea, our technology teacher built one of those. he ended up drawing soo much current withthe leafblower, that the extension cord (it was only 18 gauge) overheated and melted the insulation. i bet he was dropping more power than the device was intended to have go through it.
the SPECIALIST Posted - Nov 16 2003 : 5:41:18 PM
heres a really simple hovercraft design.
http://www.amasci.com/amateur/hovercft.html
might not be the best but its cheap and easy to build
cirvin Posted - Nov 16 2003 : 5:23:32 PM
yea, and twist the belt 90 degrees. that would work, but it will slip and it takes alot of space.
gokartmaniac Posted - Nov 15 2003 : 05:20:55 AM
Seth A. Meredith
Aaron Cake Posted - Jan 04 2003 : 12:00:19 PM
If it's a standard vertical crankshaft lawnmower engine, then don't waste your time trying to use it. It can't be run on it's side, and it's a serious pain in the ass to change the orientation of the shaft via gears (or a transmission). Find a horizontal crankshaft engine, then get a centrifugal clutch from a small engine shop, surplus store, karting supplier, etc.
n/a Posted - Jan 03 2003 : 11:09:23 PM
well i have an old lawnmower so i want to convert that but... i dont know how to do that. yes thats the evil question you didnt want. i was thinking like removing the blade and putting a chain type deal. but then it would only have 2 speeds. stop and go. im really lost.
Aaron Cake Posted - Jan 03 2003 : 8:37:55 PM
What specifically do you need to know about the engine?
n/a Posted - Jan 03 2003 : 7:16:39 PM
most of those sites had how to build the frame of a kart. i kinda need how to do the engine. i have a small idea but its wrong. i guess i should have specfied better.
Aaron Cake Posted - Jan 03 2003 : 2:51:59 PM
http://www.google.ca/search?hl=en&ie=UTF-8&oe=UTF-8&q=hovercraft&meta=
http://www.google.ca/search?hl=en&ie=UTF-8&oe=UTF-8&q=yard+kart&btnG=Google+Search&meta=
