 Spudguns
 Combustion Guns
 IR Detanator
n/a Posted - Jan 07 2003 : 4:34:12 PM
well over the weekend the combustion chamber suddenly blew up as i fired it. It almost took my arm off. So.... i was woundering if it was possible to use the IR Remote(found here http://www.aaroncake.net/circuits/irremote.htm)in the electroincs site to create a spark to set off the gun instead of igniter. Any one got any ideas?
12   L A T E S T    R E P L I E S    (Newest First)
n/a Posted - Mar 08 2004 : 08:20:54 AM
my pipe blew up cause i got a crack in it.
luckily nobody got hurt
jast Posted - Aug 07 2003 : 7:05:22 PM
Nah Mine is all pvc. Abs is hard to get around here. i dunno why. It seems like its the other way around for everyone else. This one has duct tape and sheet metal.
n/a Posted - Aug 07 2003 : 6:14:42 PM
shit are you all mixing ABS and PVC if you do it will explode and uses PVC glue not all purpose glue my first gun I used an ABS barrel with a PVC chamber and the barrel blow up but my new gun it is all PVC I aint had no problems with it
BEatonNo1 Posted - Jul 16 2003 : 7:21:55 PM
Only ONE!?
jast Posted - Jul 15 2003 : 10:27:05 PM
There's one of us in every town
cirvin Posted - Jul 15 2003 : 7:11:41 PM
alleluja!! i never knew there where so many maniacs like me!!
jast Posted - Mar 12 2003 : 4:29:39 PM
When it blew up did it shatter or just blow into 2 or 3 large peices? What was the diameter and size of it and what was it made out of?. My first gun blew up but it was just a chunk off the back. i wrapped the barrel in 4 or 5 layers of duct tape and the tape was cut clean right along the egde not fraid or anything like you cut it with a razor. I didnt think the tape would kepp it from blowing up but at least from shattering. My new gun is wrapped with aluminum flashing about 3 layers and 5 pipe clamps. I also build An add on 6" inch chaber to screw onto the 4 inch. First time used it i forgot to glue the 6 to 4 inch fitting and when i set it off the respective peices blew about 4 feet away from the tripod on both sides but that time i was smart and have 20 kv wire going from my bbq igniter to the gun.(I have more fittings on that then i have in my bathroom.) I only used aqua net but have been thinking of useing propane.
Edited by - jast on Aug 07 2003 7:07:44 PM
n/a Posted - Feb 13 2003 : 11:36:46 AM
An entertaining and useful website to view while recovering from potentially fatal injuries.
http://www.DarwinAwards.com
n/a Posted - Jan 16 2003 : 4:37:01 PM
Guys your are so crazy to play with that.
But it's so COOL.
Take care
Aaron Cake Posted - Jan 08 2003 : 4:09:48 PM
Well that sucks. Feel better.
n/a Posted - Jan 08 2003 : 2:59:33 PM
have to get some stuff done on my arm now. i tore some tissue and cracked some bones. well s*** happens. thank you very much sir.
Aaron Cake Posted - Jan 08 2003 : 09:56:37 AM
Actually it's pretty easy. User the IR Remote circuit to activate a relay wich controls the ../circuits/hvgen.htmhigh voltage generator[/ulr]. Simply replace the power supply section of the HV generator (T1, C1, BR1, etc) with a 12V source (battery) and connect the relay in series.
