| n/a |
Posted - Feb 12 2004 : 9:50:29 PM HI FROM MEXICO CITY GUYS...IM ABOUT TO START A NEW PROJECT...I BOUGHT A 5 HP. HONDA ENGINE TO MAKE A GO KART...BUT THE QUESTION IS HOW FAST CAN GO? I JUST BOUGHT THE CENTRIFUGAL CLUTCH AND I DON¨T KNOW IF WILL BLOW THE ROAD? CAN YOU GIVE SOME TIPS? THE FIRST TIME I SAW A GO KART I WAS 4 YEARS OLD...AND IT WAS LIKE AARON´S GO KART (THE FRAME MADE OF WOOD)...I WILL BE VERY THANKFUL 4 YOUR HELP...JAIME AVALOS
| 7 L A T E S T R E P L I E S (Newest First) |
| n/a |
Posted - Apr 05 2004 : 12:35:54 AM as orange knows (and knows from experience) the size of your engine, power, rpm, torque, flywheel, wahtever, wont limit your ideas. sure, you may be limited with money, or haven't the metal/welding materials to make a metal chassis, but mounting a gas motor on a wooden frame will need a HARD wood, not pine, but oak or plywood. 5hp? vertical shaft? horizontal shaft? i assume horizontal. so you'll need an axle, if not 3/4" -1" shank diam. bolts to mount to a frame. DO NOT skimp on anything. think your screws are strong? you'll find out when you snap the heads off from chassis stress. if they can mount 6 cylinders in a boat via wood
thats way off topic, yea.
you'll hit... around 20-25.
| n/a |
Posted - Mar 16 2004 : 12:52:02 PM quote:
What do you need to know exactly?
THE SPEED MY GO KART WILL REACH WITH ALL THE INFO I POSTED ABOVE...THANK YOU AARON.
Posted - Mar 15 2004 : 09:58:00 AM What do you need to know exactly?
| n/a |
Posted - Mar 13 2004 : 2:13:30 PM quote:
No idea. This depends on your gear ratio and size of your drive wheels.
quote: I JUST BOUGHT THE CENTRIFUGAL CLUTCH AND I DON¨T KNOW IF WILL BLOW THE ROAD?
Can you reword this? As it is written, I can't figure out what you are trying to say.
[quote] CAN YOU GIVE SOME TIPS?
Like general building tips? That's sort of hard to do without knowing anything about what you are trying to build.
HI GUYS AGAIN HERE IS SOME MORE INFO ABOUT MY PROJECT....TIRES 10" DIAMETER....CLUTCH GEAR TIPS 12------GEAR FOR DIFERENTIAL COMES WITH 66 TIPS AND SPECIFICATIONS ABOUT THE ENGINE 160CC. AND 7.5FT LB TORQUE THAN YOU 4 YOUR HELP...JAIME
| n/a |
Posted - Feb 26 2004 : 1:09:10 PM
if you want to build a basic wooden go-kart. go to steviewdr/~basicwoodengokart
| cirvin |
Posted - Feb 16 2004 : 5:48:48 PM If "blow the road" means stressing the parts to the point of breaking, I doubt you will have to worry if you take time to properly assemble and build the kart.
As for basic tips, Unless you want to invest in a differential, make the kart a 1 wheel drive unit. Trust me. It makes a big difference in the drivability of the kart. Make sure your chain drive system is lined up practally perfect or you will be plauged with jumping chains. If you plan for off roading, put a roll cage on it. Save your neck.
Posted - Feb 16 2004 : 12:02:36 PM quote:
