 60 VDC toggle switch?
MsStateDawg Posted - Aug 17 2009 : 5:57:36 PM
I am building a "dummy load" battery test circuit and need a SPST toggle switch for the ON/OFF switch. The largest battery to be tested is a 60 VDC, 0.2A max. Will the toggle switch need to be rated for 60 VDC? If so, where is a good place to find one? Thanks.
Aaron Cake Posted - Sep 07 2009 : 10:17:01 AM
Don't waste money at Radio Shack. Just check the Yellow Pages for a real electronics store. While there may not be a big difference in the price of a single switch, other components will be 10 to 100 times the cost at Radio Shack.
Walter Posted - Sep 06 2009 : 6:14:04 PM
Try Hardware store
boron Posted - Sep 02 2009 : 5:51:38 PM
I actually tend to find radio shack is really over priced where I live.
Walter Posted - Sep 01 2009 : 10:50:00 PM
Most of Toggle switches are rated: 250VAC, 125VDC min. 5Amps. So, if yours Power Supply is 60VDC and current 0.2A ( 200mA ) you are fine with that kind of switch. The best place to purchase is RADIO SHACK.
Aaron Cake Posted - Aug 19 2009 : 10:11:34 AM
DC ratings on contacts are far lower then an AC rating. This is because to break DC, full current and voltage must be interrupted. AC crosses zero 120 times per second so the contacts can be much smaller as the voltage will naturally fall off very quickly.
Most 20A AC rated switches will be fine for 2A at 60V DC.
codingplanet Posted - Aug 17 2009 : 6:19:21 PM
It maybe a better idea to use a small voltage 5-12V to switch your higher voltage with a transistor and/or a relay.
This page was generated in 0.27 seconds. Snitz Forums 2000
