 Electronics Repair
 Laser Alignment
camarofleet Posted - Aug 11 2005 : 09:22:51 AM
Does anyone know how to do laser alignment on a Stanton Pro CD player? I believe it has sony cdrom drives in it. Is this easy to do?
Rv
Kale Posted - Aug 26 2005 : 10:56:08 AM
Actually you shouldn't touch the lens at all unless you see a big smudge on it or something. If it's just a little dusty use compressed air to blow the dust off. Otherwise leave it alone.
Brian Posted - Aug 20 2005 : 8:22:22 PM
No, tissue paper is much more likely to scratch the lense than cotten.
sergiosparks Posted - Aug 17 2005 : 05:22:48 AM
see to it that rail is clean lubricate with a drop of no.1 or no.2 sewing machine oil.inspect gears with magnifying lense.In operation the lense assembly moves by jogging sometimes it can't move that freely becuase of dirt.ok to yse tissue paper to clean lense..not cotton it might scrape lense coating.
camarofleet Posted - Aug 17 2005 : 04:07:49 AM
The problem is on occasion ti will lock up and jump around between seconds one and two and it will start a song like 5 seconds in sometimes... Someone at a Pro Audio shop told me to get my laser aligned and thet it did not need cleaned?
Rv
sergiosparks Posted - Aug 14 2005 : 11:11:29 AM
if you mean focusing.. laser assembly aligns themselves..does it prompt you "no disk"?clean those ribbon wires with pencil erasers..disc motor are are alsoa cause of thse paroblem the comutator get filled with conductive dirt and slows it down or the brush
gets too thin and makes erratic contact..hope this helps.
