| polo5 |
Posted - May 24 2004 : 5:14:34 PM I bought a razor type scooter and a 17cc weed eater for five dollars each. I mounted the engine and I am going to put a peg on the shaft for a spindle drive. It is based on some of the scooters on Tzi's website. My only problem is how am I going to put brakes on the front. I don't want to put them on the back because I only have enogh cable to hook it up to the front. The brakes I have are normal bike brakes (the ones with the pads). I have the part (that you squeez with your hand)all ready on. I don't know haw to put the actual braking part on without drilling a hole in the scooter, because I dont want to. The brakes have a bolt in the diddle of thme. You are supposed to put a hole in the metal for the bolt to go through. What can I do? |
| 8 L A T E S T R E P L I E S (Newest First) |
| polo5 |
Posted - Jul 07 2004 : 7:14:59 PM I know its not the best drivetrain but i'm just a kid. I don't know that much yet. If I make another one it will be better. If you don't like it say it nicely like aaron.
Posted - Jul 07 2004 : 09:09:19 AM Either there is a language misunderstanding, or he is just rude.
Personally, I sort of agree. Spindle drive just sucks.
| polo5 |
Posted - Jul 06 2004 : 9:49:44 PM why do you say that?
| n/a |
Posted - Jun 22 2004 : 05:01:29 AM that is an very bad scooter
op |
| polo5 |
Posted - Jun 07 2004 : 08:48:09 AM I'm using a spindle drive again.
| polo5 |
Posted - May 29 2004 : 10:14:52 AM The motor is from a 17cc wead eater. When I bought it it was not running but I fixed it. I bought it for five dollars. I have changed the drive from spindle to gears.
Posted - May 26 2004 : 09:13:58 AM You'll just have to drill a hole, or get a section of cable long enough to locate them at the back (which would probably still require a hole).
| gokartmaniac |
Posted - May 25 2004 : 10:00:53 PM using bike brakes on a mini scooter probaly won't work. You should bodge together some sort of simple brake like what is already built into the scooter. Btw where did you get your motor.
www.freewebs.com/sethmeredith
Edited by - gokartmaniac on May 25 2004 10:16:11 PM |
