 Is a car with 302,000 miles worth the work.
Yerboogieman Posted - Feb 13 2010 : 11:20:34 PM
My FWD wagon has 301,999 miles on it as of 28 minutes ago, it still runs but i have one question. Is it really worth it replacing the floor panels?
I was also wondering what the pros and cons are of relocating the battery to the trunk.
Yerboogieman Posted - Mar 01 2010 : 11:13:37 PM
Yeah, I was going to ground an amp there once, then I got mad and drilled a self-tapping screw through the floor. All the way through. Not the best idea.
Aaron Cake Posted - Feb 28 2010 : 10:14:19 AM
Rusted seat bolts sucks. I had to go through that the first time I took the seats out of my RX-7. I ended up having to cut out the seat mounts and then weld in new ones. It was not exactly fun.
Yerboogieman Posted - Feb 22 2010 : 09:34:46 AM
Shocks aren't that big of a deal as long as everything isn't rusted in place.
Yeah, it's a 20 year old car, but I'm optimistic. I have an air rachet.
No idea. If the rest of the vehicle is in good shape, and the cost of repair is less then 40% of buying a new one, then it is probably worth it. Floor pans aren't an expensive job if you do it yourself, but it can be a big job depending on how much of the interior needs to be removed.
Kelly blue book value: $2000. This car has more pieces of plastic and vinyl than a car probably should have. And the seats are rusted to the floor. I'll probably do it if I can find a pair of cheap nice seats.
Aaron Cake Posted - Feb 15 2010 : 11:10:29 AM
No idea. If the rest of the vehicle is in good shape, and the cost of repair is less then 40% of buying a new one, then it is probably worth it. Floor pans aren't an expensive job if you do it yourself, but it can be a big job depending on how much of the interior needs to be removed. Shocks aren't that big of a deal as long as everything isn't rusted in place.
Yerboogieman Posted - Feb 13 2010 : 11:24:10 PM
Floor pans.
I also want to replace the rear shocks. But I'm hoping to do that within this month.
